1 - 11 of 11 Posts
What are the differences in these packages and if so what are they and why is one better than the other? Also is there a third option and what are its merits?
Muzzy 840cc w/stage 3 cams
Fourstroke tech 840cc w/stage 3 cams
Dont really know anything about the muzzy kit, does it include heavy duty valve springs??
I have the FST kit and it ROCKS, my uphill speed increased 25mph on my stretch of test highway, this was my stocker with only a VDI and tip removed vs. my FST 840 teryx with muzzy, vdi, and dalton kit!
Banned
You would have to talk to Muzzy about their cams that will be the main difference. I was told they were just using wenb 150I's,but that was along time ago. My cams are about 70 degree's longer duration the stock @ .040
If their cams don't need valve springs that will tell you it's not big enough IMO.
What is the compressor ratio on your kit?
Also is the 840 kit a bore and piston swap or do you install a whole new cylinder sleeve.
If so how is cooling affected?
I believe the FST pistons are a TRUE 11:1 CR, the original cylinders are bored and renicklesiled (sp?). Mickey may even have cylinders ready and you just send yours in as cores.
Banned
11:1, we sell it with or without the cylinders done. Everything is in stock. We have had no problems with over heating. This kit has been out for the Brute Force for 5 years now.
do you guys do the primary clutch mods by chance? recurve the faces?
have the dalton setup.
1 - 11 of 11 Posts
