Was running for a little then the oil pressure light turned on and now there is no oil pressure at all. Anyone have any ideas on what to check.
is there oil in the engine? if so, check the electrical connections to sensor?
yes there is oil and i have actually checked with a gauge and have no oil pressure not just the light. Still have coolant flow so doesn't look like the chain broke think it might be the oil bypass stuck open if anyone else has any ideas please chime in.
any ideas on how to check the oil bypass
Just pull the side case off and look at the oil pump.Maybe a pin sheared off the oil pump it's self. I have never seen or heard of a pump going bad on these motors so I would think it would be the pin.
