what does it take to fix the oil blowing up in the air box and then getting sucked down the carbs and causing blue smoke?
Many of the engine builders get into this on the brute forces when they run high rpm or long runs. Most of them run the oil level a bit low,..but the engine builders also do a mod when they do the engine. In stock form the crankcase is only vented from the front cylinder. While they have it apart,they drill a new crankvent into the rear one and T them together and that looks after it for the most part. If it is still a problem after that they use a catch can from the vent line of a YFZ450 quad in line there.
