1 - 14 of 14 Posts
I have a stupid question and forgive me for all the questions that I do have. I am just trying to learn these things so I can do my own work.
Okay! So I have put the Dalton clutch kit and the Overdrive cap on my Teryx. My question is would the Overdrive Cap affect my bottom end????? As most of you know I went to Moab this weekend and wasn't completely satisfied with the bottom end. I didn't have the right now response that I needed to pop over some of the rock ledges.
Thanks for the info.
Shane
Shane
The overdrive plate has nothing to do with the bottom end. The wieghts might have something to do with it. What combo are u using, rivets or not, how many set screws?? Did you change both primary and secondary springs with the kit??
Xchamp-
I don't know for sure... my dealer did the clutch install. I didn't think that the cap would affect the bottom end!!!! All it does is allow the belt to travel further up the sheave... right???? I will find out tomorrow on what they put in it and let you know. Does it matter with elevation or tire size????
All I can say is I didn't have the instant snap like the RZR's did and one of the rzr onwners use to have a Brute force and he couldn't believe how crappy the bottom end was. Maybe I am dealing with a stretched belt problem. We did ride in some pretty loose sand that could of stretched the belt when I was in high.
thanks-
yep, thats all the cover does. Try and find out what they did to the wieghts. If they left them empty, no rivets or set screws, that could be some of your problem. If my memory serves me right, on a stocker with bigger tires you should be running the rivets and at least two set screws, maybe all 3!! On my 840 with stock size tires I run them bare, but I have the HP for it. Check with Dale at dalton, very good guy to deal with, he will set you straight. Also ask them what your belt deflection is, should be right around an inch. If the belt is to loose it could hurt lowend. If they dont know (which is likely) pull the belt exhaust off of the cover and see if the belt is at least even with the top of the secondary sheaves. If its below, its to loose. A little above is very good.
BTW, I need a deal on a diamond for the wife, hers fell out of her ring!!!:D
I have asked Dale to check this thread out...when it comes to clutches, if he cannot fix it I am not sure it can be fixed ;)
XChamp-
Thanks for the info. Who did your 840 kit???? I want one but they say that you can't until a fuel controller comes out, however isn't there already to of those out? Two Brothers and Muzzy both make controllers.
Also, I will be more than happy to help with the Diamond situation!!!! Did you have insurance on it? What Ct. weight do you want to go????? Call me or PM me for more info!!!!!!!!!!!!!!!!!!
What was it like before you put all that in?
HW-
I don't know????? I had the kit put on it before I even drove it!!!!!:eek: Do you sell the deflection tool for the belt adjustment????? And if so, how much????
XChamp-
I have the FST 840 kit but its in an 08. Muzzy has a fuel programer for the 09's, but I dont think its enough for a bbk yet. Sounds like some companies have them in the works, hunterworks could probably tell you better.
Diamond was about 15 yrs old, no insurance, no idea what it was and what she wants, prob. something set in her existing ring, we havent even starting looking yet, when we do I will PM you, thanks!!
Ya I am not thinking the existing fuel controllers out there will provide enough fuel for the 840s just yet. With that said, does anyone know if the OEM injectors are capable of delivering enought fuel with a controller?
Xchamp-
Thanks again for the info. Yes, I am way jealous that you have the 840 kit. I sometimes kick myself in the butt for picking the 09'.
Ouch on the Diamond (insurance wise). I will treat you right and spend all the time necessary to educate you on the Diamond buying process. All I can say is that if people thought Used Car Salesman were crooked they don't even compare to a crooked JEWELER. Don't be afraid to ask me anything about Jewelry.
I may buy the 840 kit tomorrow from FST because his sale ends tomorrow and then just wait till the fuel controllers come out. What do you think???????
Thanks Again-
Shane
Looks like I will be doing a 840 kit later when the MSD is out so we can get to the bottom of this. They will be sending me a prototype unit a couple months before production starts, should be here in May.
I don't think you need a deflection tool, just check to see where the belt is riding in the secondary sheave, ideally the top of the belt should be even to slightly above sheave. You can see it good if you take the CVT exhaust snorkel off the rear.
Hi Shane,the others have given you some straight advice here. It would be nice to know the actual deflection of the belt itself,as different length belts from factory tolerances can make any other method of checking it a bit subjective. Also would need to know the exact set up of the kit and machine.
email me [email protected] or call anytime 902-897-3333.
Those Razr S in certain types of tight situations are pretty quick from my limited experience,but I'm about to find out more as we have a new Razr S being delivered next week (hopefully).
Discussion Starter #14
Helix-
Thanks for the info. So you are saying I need a deflection tool????? I will try to tear down the machine just enough to check the deflection tonight. I will also check with my dealer to find out how he set the clutch up.
Thanks-
Shane
1 - 14 of 14 Posts
