My wife likes to leave my parking brake on and drive off. In addition, I noticed last summer that the Teryx likes to run hot when pushed hard for long periods in soft sand. Both the Yellow Parking Brake light and the Blinking Temp light on the LE are hard to see.
I sat down, looked at the wiring diagram, and bought a couple of buzzers from Radio Shack. I have not wired them up yet, but I have put together a small wiring diagram to keep myself from getting confused.
The only one that I am not sure about is rather or not the Neutral wire will have enough low voltage Positive to trip the relay. The Oil and Temp should work fine. I will try to put it all together this weekend. I have attached the wiring diagram.
If this works, it should let me know if, A-the Parking Brake is left on When put in Gear, B-The machine runs hot, C-the oil Pressure drops.
