Hay everyone had a little problem climbing over a downed tree. I cracked the black plastic located above were you would mount nerf bars,its more like shatered. I am buying a plastic welder and need to find out what kind of plastic it is so I can match the material. thanks for the help.
You might consider nerf bars or metal wrap around pieces in that area if you are climbing over lots of trees.
Good luck with your search.
I bought a new one for the right side and I don't think it was even a $100 Canadian from the dealer. I would think you can pick it up from a dealer for $60-$70 USD. Plastic welding did not hold up for me to well when I did it. I have one and couldn't get the right rod to stick well to it. Ended up using a heat gun and melting the crack back together, held together for 4-5 rides. Good luck.
My dealer quoted me $75.00. Not too bad for how big the piece is. Still think it was a bad design from the factory .
