what is it gona teke to get the teryx up to par with a rhino or rzr thats hot some mild mods like air filter exaust an fi controller
DynoTek CDI makes the biggest gain then you should look at the Hunterworks jet/spring/TPI valve kit. Everyone seems to rave about the Muzzy exhaust as well. Read up on Hunterworks advice about the vacuum required for the CV carbs, don't just take the lid off or it will cause the carbs to not function right.
Just the CDI and you should work over Rhinos and give RZR's a run for the money
And if that isn't enough you can always go big bore 840 kit. Jaybo is right on though when it comes to easy bolt ons for the most gain.
They are right for not so much money and not so much work, you can do a CDI, our carb/ air intake kit and pull the spark arrestor out for about a 6hp peak gain.
Don't let that number fool you, with these simply mods you will be spanking basically all modified Rhinos and keep up real good with a RZR.
Thanks guys for the recommendations!!!
Discussion Starter · #5 ·
thanks everyone for their tips im thinkin of going with the muzzy duals air intake an a cdi
what kind of power could i expect with these mods
been lookin at doin a big motor but will be mostly woods riden so i dont want a motor thats gonna load up if im puttn around on some tight trails what kits r you all running
Sounds like a good plan let us know how it works out for you.
