1 - 14 of 14 Posts
I own a 2008 teryx and I was riding it today and i shut it off to run in the house and when i came back out to start it I got nothing!! I mean the lights wouldnt even come on!!! The battery is new and the connection is good! I checked the 4 fuses located under the seat by the battery and they were fine!!! I dont know what else to do???? Please help!!!
make sure it's in Neuntril. The rod might need to be adjusted, Play with the shifter until the N light comes on with the key on the ''on'' postion. Or try pressing the brake pedal hard to start it.
The battery is not dead! It is fully charged!! I went out this morning and I got it to turn over but it was cold and shut off. I tried again and nothing. I cant even get the lights on the dash to come on when you turn the key??? Its like there is no battery in it!!
does the headlights come on?
Battery problem
I have 2 kawasaki V twins and they will not start with even low battery. It sounds like your battery is bad- try jumping it. The kawi loves a good strong battery. Good luck:)
if u jump it and it starts then the battery is junk. if u jump it and still no lights then u have a wire problem.
I know its not the battery. I just charged it the other day. It turned over this morning fine!! Its like when I turn the key its not turning on. I mean the lights on the dash wont even light up!!! I mean even a low battery will light those up!!! Is there any way to bypass the key and just get it started so i can get it into my garage????
Discussion Starter #12
Guys i have it in neutral and I pushed the pedal to the floor. Even without being in neutral and the pedal pressed when I turn the key the dash will still light up. I cant even get the dash to light up??
your pressing the brake pedal right? I had a simular problem with mine. I would be riding and I'll shut it off, then I'll go to start it and nothing even the "N" would not come on. But I moved the shifter to H slowly and the "N" came on and then it started. But if U pressed the brake pedal and crank it over and got nothing that isn't the problem.
By chance do you have a winch connected to the battery and have a bad connection between all the wires. You may have a ground problem - You may need to start tracing wiring. I know you have ruled out the battery but a battery terminal may be broken or lose. again Good Luck .
1 - 14 of 14 Posts
