We have a 2008 teryx. The oil light came on cause it was low. We change the oil but now it will start but shut off. I dont think the motor is seized. Any suggestions?
I am no teryx mechanic, I actually just bought one last week, however i seen nobody was helping you out so I figured I would take a stab. Did you try disconnecting the negative battery terminal for a couple minutes, this should clear the ECM of any trouble code it has unless the sensor sends the code again. Worth a try.
