So i heard the wires in pouch under bed can be used for reverse lights as long as you add a relay, the 30a relay i bought has to posts and i'm wondering which of the to wires goes to the relay and where the other goes, i dont wanna fry the reverse switch if i can help it, also the lights i bought are non led and will be mounted behind the headrests so if i could trace those wires from the bed up to the batt box somewhere that would be sweet, any hints where there at?
You shouldn't need a relay.
I had a driving light that had both the positive & negative wires running out of it. Just plugged it in & it works fine. I've had it on several months now.
