1 - 1 of 1 Posts
Hey guys i have a new 2011 teryx sport and im trying to wire up a reverse light for it. Ive done all the research on the wiring part and i know that part is correct. But, for some reason my reverse light on my dash wont even light anymore. And I did confirm the plunger switch is good as i tested it with my test light and swapped it with my neutral switch and it does the same thing. (the neutral light works) I also tried adjusting my linkage both ways and it still will not connect the ground to light it up! Any one have any ideas as to what might be wrong here? Another thing i might want to note is that i have everything tore apart to adjust the belt(waiting on a puller) and i wasnt sure if something i may have unhooked has anything to do with the reverse light not working or what? Any advice is appreciated! thanks,
Ty
1 - 1 of 1 Posts
