If any one has changed theirs can you get me instructions on how you did it. It really doesnt look that bad but I dont know what order to start taking things off. Last night I was going to start with taking the lower shock bolt out first but I cant even get the bolt out. It is like there is to much tension on the bolt to come out. I am also worried about doing it by myself if I will be able to get the tie rod and control arm blots back in by myself. And how the heck will I get a torqe wrench on the control arm bolts to torqe them?Any help and tricks would help alot. Thanks guys....
for the shock part you have to take the weight off the that wheel. jack stand under the frame, use a jack to slowly lower the a-arm till there the bolt is loose. The rest I havent done yet.
