I am getting ready to install a KFI Stealth 4500. I want to replace the standard toggle with a rocker switch to fit in the factory molded cut-outs. Has anybody done this before? It is a Teryx4 2017. Can I keep the wire that comes with the winch and disconnect the toggle and use same wires for the new rocker switch?
Hi..i am a new user here. As per my knowledge you might not be able to have an accessory position with a toggle switch, they're just not setup that way. You will need a 2 way toggle switch, OFF and ON. You will need a test light to find out what wire does what, and when you do, write that info down along with the color of the wire. One wire will be battery HOT, one wire will be key HOT, and the rest will be accessory or key hot, along with the starter wire. Your picture explains the function of the wires, but double check them, and mark them.
