vent hose fuel spewing
So am I the only one that has experienced fuel running up the vent line and filling the cross bar with so much fuel that it ran down the line for the rear diff.?
I went out on a ride, nothing severe put plenty of side-to-side rocking. I smelled fuel, stopped to find fuel but with an oily residue all over the passenger seat back. I pulled the fuel line from the roll bar and a good cup worth of fuel ran out of the fitting.... since the rear diff. vent was the lower hose on my roll bar, it somehow mixed oil inside the roll bar and I had an oily mess to clean up and diff. fluid that was obviously mixed with fuel.
I have since swapped the hose locations on the roll bar in case it happens again. I have disassembled and cleaned the fuel tank vent valve. I have run three oil changes through the diff. after running a few miles to circulate the oil (hydraulic fluid actually)
I've looked all over and no one else has had a similar problem I guess.
