I’m having a problem with my 2014 Kawasaki 800 teryx4. When I give it gas it spits and sputters. I have checked fuel filters,changed spark plugs,checked valve clearance,changed injectors,and checked exhaust. It has 44 lbs of fuel pressure and stays there when trying to ride it.it also backfires through the breather. Any help would be great because I’m stumped
Teryx4 2019 , Alba flash ECU light bar mod lights rear HD bumper Boss radio,RPM /temp gauge horn
did you check your hand break ,my was doing something like that and it was the hand break swich ,push your hand break all the way down and hold it down and try againg, make sure the swich is good
