I am against them all, just do it homemade and make sure you use at least a 3" tube or pipe on the exhaust side
You figure 2" is to small. My wife seems to like it. :laugh: Bigger would definatley be better but it is a pretty confined space for a neat 3" install.
2" inch is what I am running. Even with 2" or 3" the heat will build up and the belt will get hotter than usual. I am running two 12volt blower motors to blow in fresh air and to suck out the hot air. It works really well. I am also about to plumb in a 12v bilge pump into the clutch housing using the drain as the tie in point.
