something broke in the front end of my teryx made a loud pop and quit pulling axles are good .hoping theres some cheap part in the front diff if anyone can help that would be great .
Maybe be something very simple, the 4wd engagement mechanism is simply a collar that rides on the input shaft being pulled backwards on the shaft to engage the teeth on the front yoke.
Could be a bunch of things actually....
I've personally grenaded the entire clutch basket in the front diff. It took all those clutch disk in there and turned it into confetti.
Spider gears could have popped as well.
Or simply not be engaging in 4wd but thats pretty easy by simply making sure the lever is moved forward on the front diff.
