Do you guys think a Teryx will need to be rejetted after a std bore install. For now it has stock exhaust and air box what do you think?
Oh yes for sure and not sure if anyone can tell you what jets to use every vehicle is going to be different and also the numbers on stock jets and dynojet jets don't mean the same thing.
So the Unifilter and the carb/air kit is all i need. This would be an addition to muzzy and standard bore, and CDI.
No you would need some larger jets than comes in our std kit but we should be able to hook you up
You also HAVE to change your clutching and I recommend the Dalton.
The stock clutch weights will be way too heavy for the 840 kit
