So I am rewiring my stereo and other items and was wondering:
is it possible to wire the speakers such that they will play with or without the amp? Right now the two pods and the sub go to the amp and only play when the amp is on. There are times I would like to play without the amp, is that possible? I am using a Sony hu and amp and using their special harness.
Yep.
Sometimes I am working on it or testing something away from my garage and want some tunes without the bass or power otherwise required to overcome engine noise. It's not a huge deal, just wondering if doable.
How many amps you gonna run? If you run a seperate amp to the sub, the just put a switch in your remote wire. That will allow you to turn it off whenever you want.
