I have an 08 Teryx with about 145 miles on it. When I pull out, especially in high alot of times it starts jerking and makes a slight chirping sound for just a second or two then its fine. Whats going on? Is my belt loose, too tight, what do I need to do?
Thanks for any info.:wave:
Belt adjustment
Have you adjusted the belt before? If not check belt deflection. you will need to take a shim out of the driven clutch.:wave:
