I posted this below on another 'starting' problem thread. Something amiss with the spark on this things. I also have to hold the choke out.
I’m having a bit of the same thing. Most of the time I use the Teryx everyday, and starting seems sluggish for it to fire, but not that much of an issue. But when away from the ranch, it may sit a few days without starting. Yesterday morning I tried to start after sitting for about 5 days. It turned over fine, but just cranked. After awhile I could smell gas. I let it sit for 5 minutes, tried to start again with choke off…it coughed. Finally it started without the choke on, but dies. Tried again and once it barely got started, gave it some choke…and finally it caught and ran.
It obviously had to much gas, but still seem to need choke to run. I think this is spark related. Did the Dynatek CDI not give enough spark to fire it on the initial starting, but it pull gas in finally flooding? Even though it cranked fine, something is going on with these Teryx’s on the spark side, be it low voltage, even though battery will crank or something else. I think the cold aggravates it. It was near freezing that morning, but the Teryx was inside an unheated shed.
Does it need a ‘hot’ battery to work? Does it need the aftermarket voltage change? Does Dynatek need to fix a problem they have with spark delivery? I’m not smart enough to figure it out, I hope someone is.
