1 - 11 of 11 Posts
Click on the attached PDF Document. This document can be opened using Adobe Reader, and can be saved or printed.
Below are a list of oil filters that should fit the Teryx. I tried the longer (3.1/4") Filters, but they would not fit due to clearance of the radiator hose. So I only listed the 2.5" long filters.
Each of these oil filters have 20 x 1.5mm threads, 14psi by-pass valve, anti –drain back valve, 2.3” O.D. gasket, and are approximately 2.5” long. I have not personally tried each of these filters, so this is for information only. Each filter should be compared to the factory filter prior to installation.
Motor Cycle Filters
1. Kawasaki 16097-0003
2. Honda 15410-MCJ-000
3. AC Delco PF2135
4. AMSOIL SMF103
5. CARQUEST 85358
6. FRAM PH6017a
7. K&N KN-204
8. NAPA Gold 1358
9. Purolator ML16817
10. STP SMO-17
11. WIX 51358
Automotive Filters
1. AC Delco PF1237
2. Baldwin B1400
3. Bosch 3300
4. Firestone TF2876
5. Hastings LF113
6. Mobil M1-108
7. NAPA Gold 1365
8. Purolator L14612
9. Purolator Pure One PL14612
10. STP S-02876
11. Wal-Mart SuperTech ST6607
12. WIX 51365
I use mobile one oil & filter...
The best way I found to get the old filter out (for those with large hands) is to jam a screwdriver through the side of the old filter and use that to rotate the filter around.
I don't have one small enough...
And besides, I have plenty of screwdrivers lying around, would have to spend some $$$ for another filter wrench!
The oil is measured with the cap screwed down or just resting on the opening? I ask because the Artic Cat is measured at the resting level - not screwed down. Their rear diff oil level is measured with a 8" zip tie bent at the part where the tie starts to zip, yep just past the pointed part at about the 1" mark, per their shop manual.
Which oil filter would you recommend and type of oil?
Hunterworks now handles the Amsoil synthetic oil line and will drop ship an oil change package...(3) qrts Amsoil Formula Four Stroke full synthetic powersports oil and (1) Amsoil EAOM-103 NANO filber oil filter right to your door at factory direct pricing!:)
removal of drivers side seat
I just purchased a 2008 Teryx with mastercraft seats and 4 point restraint attached to horizontal tubing behind the seat. I want to check and replace the oil. How do I easily remove the seat without taking the restraint system apart? Are their any tricks?
1 - 11 of 11 Posts
