I am in the process of installing a dalton clutch kit. Does anyone know what the torque specs are on the 27 mm bolt on the secondary and the specs on the backwards threaded bolt on the primary? Also what are the torque specs on the 8 small bolts on the over-drive plate?
from the service manual....
Converter System
Drive Pulley Bolt 93 9.5 69 R, Lh
Drive Pulley Cover Bolt 13 1.3 113 in·lb
Ramp Weight Nuts 7 0.7 62 in·lb
Spider 275 28 203
Driven Pulley Nut 93 9.5 69 R
Engine Brake Actuator Mounting Bolts 8.8 0.90 78 in·lb S
Engine Brake Actuator Cover Bolt 8.8 0.90 78 in·lb S
Belt Inspection Opening Cover Bolts 8.8 0.90 78 in·lb
Converter Cover Bolts 8.8 0.90 78 in·lb S
Converter Cover Drain Bolt 20 2.0 14
Joint Duct Bolts 8.8 0.90 78 in·lb
