1 - 1 of 1 Posts
Well I'm just curious if anyone else has been having a problem with low range trying to pop out of gear? Seems to me like the steering column doesn't have enough support and it moves/flexes. Even after adjusting the linkage it still had a problem so basically now I've had to adjust mine so far foward that it goes into reverse but in order to make the light come on you have to pull hard on the shifter. Before I did this under a hard load it would sound like it tryed to jump gears but after the adjustment it seems to be doing fine.
This happened to both the built teryx's in the group and its starting to make me wonder if the column needs to be supported some kind of way.
1 - 1 of 1 Posts
