I'm curently running 14'' ss212 /26'' original bighorns 9's up front and 11's in back. Been playing around with different pressures I'm at 16 in front and 19 in back . anthing less and it seems the side walls have flat spots when driving. I just took off outlaws but the side walls where alot stiffer so I only ran recommended tire pressure 9/13. any help would be appeciated
I run 13f and 13r on my Grim Reapers. Have never had a puncture, just a few broken rims.
I run bighorns with 14 inch also. I run 14-15 psi front and back. When I was running less than 10 psi I was breaking the bead. I run trails and rocky stuff at Ocitillo Wells mostly.
Tires is my life, about 35 years in the tire business, different tires, wieght, and riding conditions make it hard to come up with a perfect air pressure for everyone, because higher and lower air pressure both has its pros and cons.
