Teryx Pro Exhaust System by Muzzys
UTV Crap
I have the Muzzys Pro exhaust system. From what it looks like, the UTVCRAP Alternator will not fit (see Mount Area pictures).
I'm also thinking that the Alternator will not fit in that area and may have to cut a hole in the wall of the battery compartment?
Does anyone know of better instructions/pictures/videos of this install?:confused:
Thanks for all your help.
i have the muzzy pro on my 08 that i installed about a month or so ago and it is nowhere near the oil dipstick and side cover like yours.....there must be different bends on those or something.?i have trouble with mine hanging down where the skidplate is?i will have to take pictures to show you guys.:confused:
Looks to me like that's the stock plastic cover, it's gonna melt on your first ride even with all the heat shielding.
have you looked at the aftermarket stator? i think that will be the route i am going once i pull the trigger... wont be throwing belts with a stator!
I've had no problems with wrapped Muzzys and the stock cover. In fact, just took the stock cover off today to check the valves and it was fine.
Adjust the valves?
The pics you show of the front Muzzy's headpipe#2 Jakbone is the standard not the PRO exhaust system. The PRO system follows the path of the stock system and is way below the stator cover. Get the Muzzy's metal stator cover and you will be all set with the system you have.
adjust the valves?
The pics you show of the front muzzy's headpipe#2 jakbone is the standard not the pro exhaust system. The pro system follows the path of the stock system and is way below the stator cover. Get the muzzy's metal stator cover and you will be all set with the system you have.
x2 ^^^^^^^^^
with our newest verison and the free upgrades we gave out we have no longer had any belt issues. Thanks for the concern though.
ur welcome...
