1 - 1 of 1 Posts
Hi guys I have a problem not sure what left to do I have serious vaccum flutter in the rear cyclinder. Checked slids and valves. did a cyclinder test almost 175 rear front is a little low at 150 but still have to check valves on front. Just got it back from dyno ran great for a day then started to bog hard at full throttle. 5500 max rpm. Need to sync carbs but flutter prevents that. Front cyclinder is solid at 14.5 cm Hg.
840 420 cam lift 11.5:1
thanks
1 - 1 of 1 Posts
