So I finally hooked up my vapor completely (except the speedo) and everything is working except the vapor won't read the water temperature. There is only one way to hook it up and I can't seem to find why it's not reading. Can it be the sensor is not working correctly?
If everything is hooked up correctly and you are still not getting a reading, I would say that could be a possibility. If I remember correctly, I think there might be a trouble shooting guide in the manual. Also, did you configure the settings on the unit?
I configured the settings on the unit and unfortunately I lost the manual. I went through the whole menu settings and the only adjustable setting is the warning temps that are adjustable and I have it set to read Fahrenheit. The only thing that is currently displayed is a bunch of dashes. However, It does read the ambient air temp.
you have to change it to mode number 2 for water temp. If it displays ambient temp it is in mode 1, they cannot both be displayed at the same time.
vapor anwser
hope this helps
Perform a two button reset (<LEFT> + <MODE>.) Vapor will not display temperature
until the reset is performed (telling Vapor to look for a sensor.)
Vapor will display “- - -” for engine temperature until it reaches 100°F (38°C).
hope this helps
That worked!!! Thanks for all the help!
