1 - 19 of 19 Posts
If you are going to have your teryx dynoed have them remove the front drive shaft first and this can be done without tools well at least removing the shaft part. You must remove the plastic center plastic floorboard cover.
The end of the drive shaft that goes to the front differential has a spring in it and you can push the drive shaft forward and it will come out of the engine yoke. After removing the driveshaft pull the yoke off the engine as well, it just slips off.
Oh yeah the reason why. When dynoing the Teryx the front drive shaft turns on the input shaft on the front differential and it is not designed to be turning that fast compared to being on the ground. The front yoke has a brass bushing in it and it will get the front yoke so hot it will melt the seal inside yoke right behind the nut that holds it on then the oil will leak out. If you continue to run it, you will destroy the input shaft as well.
When not on the dyno and you have it in 2wd and the rear wheels spin the shaft spins on the front input shaft but it is not long enough to do damage but when you do continuous runs it gets very hot.
Point is, remove the front drive shaft before you dyno you Teryx. Just ask me and Dieselpowered we both have had to replace the front yoke and the seal in it.
Diesel why don't you stick the thread?
Yes I think I will since I just had mine fixed for the very same reason. Now I am not pointing fingers saying they did not remove the front drive shaft when they dyno'd but I just had this exact same problem fixed on mine.
Had my rex dyno'd a couple of weeks ago. Didn't know about the front drive shaft seal, I don't think they removed the front drive shaft.....You think it's gonna leak huh????????
Kelly at KMS dyno'd mine without removing the front shaft.
needed a new yoke as well as the seal. We had to pull the front diff to get to the shaft to remove all the old bushing material. PITA and $140 in parts. Labor we did ourselves.
Ever since I snorkeled my bike, it has been harder and harder to get it out of 4WD. So I said screw it and left in 4wd all the time not thinking it would hurt anything. Parked my bike after the last ride behind my house. Went to back it up the next day to go clean it, and it wouldn't move. I forgot to mention I smoked the belt that ride also. I tried to back it up to move it, and it wouldn't move. It would roll back just a hair, and thats it. Thought maybe it was the belt issue that I already knew about. Pulled primary and belt. Still wouldnt move. Jacked it up off the ground, same thing. Turns just a little, then stops. Upon further inspection, I noticed the front seal just hanging around the front shaft. Then I noticed why it wouldn't roll very far. It would roll just enough in the hit the almost gear looking thing right behind front seal. I'm guessing that is what engages 4wd. I also noticed that my front prop shaft is no longer centered in the diff. Can't wait to tear it all apart and find out what's wrong with it.lol. Guess my main question is did all this come from riding with it in 4wd this whole time? It has probably been a few months of not easy riding.
I am hoping i don't have to rebuild the whole thing. Haven't tore it apart yet though.
Is there a trick to getting the axle nuts off the axle? I tried using my impact, and it wouldn't budge. Are the both right hand thread?
Is there a trick to removing front shaft? I tried sliding it forward like everyone says, and its not moving as easily as everyone says it does. Could it be becasue it is stuck in 4wd? Also, how do you take aprt the front yoke to get to the bolt to remove yoke from diff?
Discussion Starter #12
On the axle nuts, get bigger impact.
The idea that being stuck in 4wd would not affect the stuck drive shaft.
It is spring loaded and pushes toward front diff and comes out of of the u joint yoke on engine, it might slide off engine as well.
To take apart the front yoke, there is a C clip on the inside of the Ujoints you must get out on two sides then slide u joint to one side to remove cap then other side to remove that cap then remove U joint.
Thanks, you're a hughe help. I feel like a dumbass. This whole time I was trying to push the front u-joint assmb. into the differential and not the shaft.
Im new to the teryx world, but have worked on mine alot, need to replace front diff seal an no clue how to get u joint apart to get to nut behind it
Discussion Starter #18
Which seal you replacing?
If the big outside I think it will slide over drive shaft yoke.
If little one, you have to remove the clips on the inside of the U-joint on two sides then push U-joint to one side, remove cap then push to other to remove that cap then take apart.
Great info!!
Thank you so much for sharing your knowledge, I am learning by the minute!
Support the troops abroad and at home!
1 - 19 of 19 Posts
