i need to know that size socket to remove secondary pulley? when i removed my cvt cover where is the oil coming from from small bolt on cover that i didnt need to remove.
There is an oil line behind the tin plate that is behind the primary clutch. It has o-rings on it and they could be leaking. I found out the hard way that you can get oil in the CVT cover if those o-rings are not good. PS note to self, do not run engine with tin plate removed, it holds the oil line and o-rings in place!!!! :(
