Looking for a 10,000 tach to install in my teryx, only ones i have found are the 5" monster tachs i am looking for something smaller and cheaper just want to use it to get my clutch tuned perfect.
call hrt in ramona and get the vapor dash.....tach, temp, speed etc....holds info 130.00 great piece
I use the Vapor dash in mine. What is nice is that the Dynatek has a tach output wire that you can hook to the Vapor :good:
Can't you use that same output wire on the dyna for any tach? anyone find a small affordable tach, looking for one also on clutch tuning.
I didn't ever look into tachs before. I just did some research that I should have done a while back. Only tach I ever use on a UTV was on the dyno and it clips to plug wire.
Most tachs connect at the coil and and if the coil is getting 8 fire signals such as a 8 cyl car then the tach needs to know to divide the pules by 8 to get the rpm.
The issue on some single cylinders is the plug fires a waste spark which means it fires on the exhaust stroke as well. The tach would need to operate for a two cylinder then to get the RPM right.
My timing light is a good example of that, it reads twice as high on the Teryx until I switch it to 2 stroke.
Looks like the Tiny Tach Commercial would be a good tach, not expensive and picks up every 1/2 sec. Totally programmable to what ever ignition type you have.
Making me think about this reminded me I could just use my timing light as a tach when doing road testing.
hey i didnt research anything, all i did was google small diameter tachometers... i dont want one so no need for me to read and research....
