· Registered
im running the lowrance 540c loaded into the dash where the stock dash was. i love it! it is easy to use and read....i have it showing the gps speed, altitude, time, and volts on the screen. i think it is discontinued now, but i have no experience with its replacement model...
· Registered
Go to the Lowrance site . I believe it was replaced with a 7 . As in 740c ?:confused:
· Registered
Regardless which gps you pickup. Make sure its color. Don't cheap out on the black and white display because its alot cheaper. If you do you will quickly realize that dirt roads resemble brooks and streams.
I personally use Garmin GPS on my UTV. I've had great luck with it and it works great.
· Registered
what model Garmin do you use
