Just installed dalton clutch and now machine will not start. While cover was off i started it several times to check things out. All looked good so i buttoned it back up and now it will not start. Got charger on it right now and will try to start when i get home. Maybe just a coinsidence and something else is wrong. Or did i leave the key on at some point???? Don't know if i did or not!!! Question is are there any relays or electical issues i should check??? Any suggestions would be appreciated. TY
Discussion Starter #2
Well guess what??? I installed the dasa kebc block off plate and used the bolts that i removed to fill in all the holes and they are to long. When i put the cvt cover back on one of the bolts would not let the primary turn because the bolt would stop the primary from turning. Put shorter bolts in and all is fine. Maybe Dasa put that in the instructions or not, i don't know but anyway make sure bolts are short enough.
Yeah i didnt think to tell you about that.
