Need to purchase a right rear cv joint. Mine started clicking real bad on a ride and took it apart to see the damage. There are alot of chips on the edges of the channels for the bearings. Its beyond repair so I need a cv joint that wont burn my wallet. Kawasaki wants way to much for one and i not sure how comfortable I feel about getting one off ebay. I heard the 2008 and early 2009 models are the same. As the late 2009 and 2010 are the same. So I just wanna make sure I get the right part. Mine is a 2009 Teryx LE. Bought it in april 2009. Thanks.
All years of rear cv's are the same, it is only the front that they changed the splines on the axle shaft, but if you had a complete front axle with cv's it would fit all machines as well. Hope this helps you out.
