1 - 1 of 1 Posts
XRRA ex-competition rock crawler, competed during the 2004/2005 season. Originally built in Colorado, was bought by a friend of a friend and brought down to Az. I bought it from him and upgraded everything that I had an issue with. Ran A LOT of trails with it, it does great. Here`s the list:
-1990 chevy 4.3L motor with about 70K miles on it. Hypertech programmer.
-turbo 350 transmission w/ manual valve body and cooler.
-dana 300 t-case. This blew up on my year year at the Chile Challenge (NM). I replaced
the tera-lo gear set with a tera-lo gearset-MUCH STRONGER. I also upgrade the
output shafts to 32 spline. Front dig, oh yea!
-front and rear dana 60`s w/ ARB`s. Front is a chevy/dodge and I added the Reid racing
5th stud knuckles and Ballastic Fabs hi-steer arms. Very strong set-up for steering. Rear
60 is a sterling and has disc brakes.
-PSC steering ram. The original ram failed, so I upgraded it to a PSC system-kept the
orbital because it worked fine. New high dollar hyd. hoses, and added a fluid cooler.
The cooler fan is mounted in front of the radiator and rarely needs to be turned on, and it
is running backwards to add cooling to the radiator (push-pull setup). Works great.
-42” Iroks (non-stickies) on allied monster beadlocks. Tires at 70% tread.
-Warn M8000 winch w/ brand new syn cable.
-suspension is 3 link in the front, and a one link in the rear.
-air bumps
-Electrical rewired because it was an electrical nightmare, added new gauges.
Still have the window nets, very easy to make this ready for XRRA. I have a lot of money tied up in it, but don`t need to sell it. Just not as interested in crawling anymore. I have a thousand dollars in Ballastic Fab brackets & heim joints and a 14 bolt (4.10), already has the bottom shaved off, Ballastic truss & rear disc brackets. Also have a spare 42” on an H2 wheel. Also have a 16” Big Tex trailer for sale as well.
$14k for everything
$13.5k crawler & trailer
$12.5k crawler
Located in Gilbert Az
1 - 1 of 1 Posts
